跳转到主内容
Royal Kludge GK64 Keyboard Switch Spring Replacement
你所需要的
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 步骤 1 中的图像 1,2 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 步骤 1 中的图像 2,2
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 2 中的图像 1,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 2 中的图像 2,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 2 中的图像 3,3
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 3 中的图像 1,2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 3 中的图像 2,2
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 4 中的图像 1,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 4 中的图像 2,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 4 中的图像 3,3
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 5 中的图像 1,2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 5 中的图像 2,2
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 6 中的图像 1,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 6 中的图像 2,3 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 6 中的图像 3,3
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 7 中的图像 1,2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 7 中的图像 2,2
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: 步骤 8 中的图像 1,1
    • Place the keycap back onto the switch and push down to secure the keycap.
结论
另外一个人完成了本指南。
Diksha Sakre
于09/19/22注册
228 声望
撰写一个指南
团队
York University, Team A-7, Morris Fall 2022 York University, Team A-7, Morris Fall 2022 的会员
YORK-MORRIS-F22SAG7
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 24
总计 618
