跳转到主内容
Royal Heat RS-100 Tip Switch Replacement
你所需要的
  1. Royal Heat RS-100 Tip Switch Replacement, Panel: 步骤 1 中的图像 1,1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Tip Switch Replacement: 步骤 2 中的图像 1,3 Royal Heat RS-100 Tip Switch Replacement: 步骤 2 中的图像 2,3 Royal Heat RS-100 Tip Switch Replacement: 步骤 2 中的图像 3,3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Tip Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Tip Switch Replacement, Switch and Circuit Board Assembly: 步骤 4 中的图像 1,1
    • Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
  5. Royal Heat RS-100 Tip Switch Replacement: 步骤 5 中的图像 1,2 Royal Heat RS-100 Tip Switch Replacement: 步骤 5 中的图像 2,2
    • Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater.
    • Unplug the wire that goes from the bottom of the power switch to the heater coils. To unplug pull down on the wire until it breaks free.
  6. Royal Heat RS-100 Tip Switch Replacement: 步骤 6 中的图像 1,2 Royal Heat RS-100 Tip Switch Replacement: 步骤 6 中的图像 2,2
    • Unplug the wire that goes from the bottom of the power switch to the fuse holder. To unplug the wire, pull the wire away from the fuse holder.
  7. Royal Heat RS-100 Tip Switch Replacement: 步骤 7 中的图像 1,1
    • Unplug the wires located on the right side of the heat coil housing. Both plugs will come off together. To unplug the wires, pull down on the wire until it breaks free.
  8. Royal Heat RS-100 Tip Switch Replacement: 步骤 8 中的图像 1,2 Royal Heat RS-100 Tip Switch Replacement: 步骤 8 中的图像 2,2
    • Grab the Switch and Circuit Board Assembly with one hand and slide it up. You will need to wiggle it to break it loose. While wiggling it, slide it up until it is clear of the plastic rails.
  9. Royal Heat RS-100 Tip Switch Replacement: 步骤 9 中的图像 1,2 Royal Heat RS-100 Tip Switch Replacement: 步骤 9 中的图像 2,2
    • Unplug the two wires, with blue ends, that go from the Power/Fan switch and from the bottom of the Circuit Board to the fan. To unplug the wires, pull them away from the fan assembly until they break free.
  10. Royal Heat RS-100 Tip Switch Replacement, Tip Switch: 步骤 10 中的图像 1,1
    • Flip over switch/ circuit board assembly
  11. Royal Heat RS-100 Tip Switch Replacement: 步骤 11 中的图像 1,1
    • Remove solder from the two terminals of the tip switch using the soldering iron.
  12. Royal Heat RS-100 Tip Switch Replacement: 步骤 12 中的图像 1,1
    • Remove the tip switch from the circuit board by pulling it away.
结论
Luke Nora
于10/14/13注册
216 声望
创作了2篇指南
团队
Cal Poly, Team 11-35, Amido Fall 2013 Cal Poly, Team 11-35, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G35
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 674
