跳转到主内容
Royal Heat RS-100 Fuse Replacement
你所需要的
  1. Royal Heat RS-100 Fuse Replacement, Panel: 步骤 1 中的图像 1,1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Fuse Replacement: 步骤 2 中的图像 1,3 Royal Heat RS-100 Fuse Replacement: 步骤 2 中的图像 2,3 Royal Heat RS-100 Fuse Replacement: 步骤 2 中的图像 3,3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Fuse Replacement: 步骤 3 中的图像 1,1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Fuse Replacement, Fuse: 步骤 4 中的图像 1,2 Royal Heat RS-100 Fuse Replacement, Fuse: 步骤 4 中的图像 2,2
    • Do not pry from the middle of the fuse because some fuses are made of glass.
    • Pry one end of the fuse from the bracket until it is separated from the holder.
    • Remove the fuse by lifting it up.
结论
Long Tran
于10/14/13注册
205 声望
创作了2篇指南
团队
Cal Poly, Team 11-35, Amido Fall 2013 Cal Poly, Team 11-35, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G35
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 598
