跳转到主内容
Rowenta Focus Power Assembly Replacement
你所需要的
  1. Rowenta Focus Power Assembly Replacement, Power Assembly: 步骤 1 中的图像 1,2 Rowenta Focus Power Assembly Replacement, Power Assembly: 步骤 1 中的图像 2,2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Power Assembly Replacement: 步骤 2 中的图像 1,3 Rowenta Focus Power Assembly Replacement: 步骤 2 中的图像 2,3 Rowenta Focus Power Assembly Replacement: 步骤 2 中的图像 3,3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Power Assembly Replacement: 步骤 3 中的图像 1,2 Rowenta Focus Power Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Power Assembly Replacement: 步骤 4 中的图像 1,2 Rowenta Focus Power Assembly Replacement: 步骤 4 中的图像 2,2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Power Assembly Replacement: 步骤 5 中的图像 1,3 Rowenta Focus Power Assembly Replacement: 步骤 5 中的图像 2,3 Rowenta Focus Power Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
结论
To reassemble your device with new power supply, follow these instructions in reverse order.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 42
过去 30 天: 175
总计 5,219
