简介
If the metal soleplate on the Rowenta Focus DW5080 becomes corroded due to mineral build up, or it will not heat up, it needs to be replaced. This guide provides instructions for the soleplate, (metal plate that forms the base of the iron) replacement.
The user needs to make sure that the iron is off and not hot before replacing the soleplate or they could be burned.
你所需要的
Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
Lift out the piece.
Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
3等其他人完成本指南。
