跳转到主内容
RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement
你所需要的
  1. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Saw Casing: 步骤 1 中的图像 1,1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 2 中的图像 1,2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 2 中的图像 2,2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 3 中的图像 1,2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 3 中的图像 2,2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 4 中的图像 1,1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 5 中的图像 1,2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 5 中的图像 2,2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Motor: 步骤 6 中的图像 1,1
    • Lift the motor assembly out of the casing.
    • The white plastic piece connecting the wires and holding the motor brushes in place is fragile. Be careful to not break it when removing the motor assembly.
  7. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 7 中的图像 1,2 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 7 中的图像 2,2
    • Detach the wire connected to the bottom of the motor assembly.
    • Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
  8. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Safety Lock Pin: 步骤 8 中的图像 1,1
    • Remove the sliding washer holding the pin in place.
    • The sliding washer is not shown in this guide. The action shows where the washer should be located.
  9. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 步骤 9 中的图像 1,1
    • Flip the saw so that the 'Rotozip' label is facing upwards.
    • Remove the safety lock pin and spring.
结论
Lauren Russell
于10/05/16注册
224 声望
创作了3篇指南
团队
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G4
4 名成员
创作了5篇指南
一条评论
Where can I find replacement parts for this Particular rotozip model #reb01 type 2
Kennith Murray - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 2,276
