跳转到主内容
加入维修社区 - 创建账户
Rotary Multi Selector Wheel Removal
你所需要的
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: 步骤 1 中的图像 1,3 Rotary Multi Selector Wheel Removal, Back Cover Removal: 步骤 1 中的图像 2,3 Rotary Multi Selector Wheel Removal, Back Cover Removal: 步骤 1 中的图像 3,3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: 步骤 2 中的图像 1,1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: 步骤 3 中的图像 1,2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: 步骤 4 中的图像 1,3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: 步骤 4 中的图像 2,3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Lift up the metal cover and its button slowly using the tweezers.
结论
Andrew Lau
于04/18/13注册
1 声望
撰写一个指南
团队
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 的会员
CPSU-JOHANN-S13S8G56
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 731
