跳转到主内容
Rosewill NEON M62 Bottom Panel Replacement
你所需要的
  1. Rosewill NEON M62 Bottom Panel Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Bottom Panel Replacement: 步骤 2 中的图像 1,1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Bottom Panel Replacement: 步骤 3 中的图像 1,2 Rosewill NEON M62 Bottom Panel Replacement: 步骤 3 中的图像 2,2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
结论
Joshua Alves
于03/16/23注册
97 声望
撰写一个指南
团队
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 128
