跳转到主内容
Roofing Tile Replacement
你所需要的
  1. Roofing Tile  Replacement, Roofing Tile: 步骤 1 中的图像 1,1
    • Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
    • Ensure the damage has not reached the underlayment.
  2. Roofing Tile  Replacement: 步骤 2 中的图像 1,1
    • Depending on where the damaged tile is on the roof, be sure to prime underlayment before adding new roof tile on top.
  3. Roofing Tile  Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the damaged tile(s) using your hammer and crowbar.
    • Be sure to use an effective safety harness when operating in unsafe conditions.
  4. Roofing Tile  Replacement: 步骤 4 中的图像 1,1
    • Use roof cement to initially attach the tiles to each other and add security to the underlayment.
    • Be sure to wear the proper gear, such as shoes, hats, & breathable clothing.
  5. Roofing Tile  Replacement: 步骤 5 中的图像 1,3 Roofing Tile  Replacement: 步骤 5 中的图像 2,3 Roofing Tile  Replacement: 步骤 5 中的图像 3,3
    • Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
    • Use the handle of the hammer to maneuver into correct position.
    • As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
    • Safety first. Don't forget to wear a harness and be sure to understand handling of cement take.
  6. Roofing Tile  Replacement: 步骤 6 中的图像 1,1
    • Walk carefully on the tiles that are already set into place.
  7. Roofing Tile  Replacement: 步骤 7 中的图像 1,1
    • Use the backside of the hammer to slide up the piece overlapping the broken one, and use a drill to unscrew any screws (which won't be necessary if you're using roof cement). Replace the tile with the new one, and glue in place.
  8. Roofing Tile  Replacement: 步骤 8 中的图像 1,1
    • This is an initial point of view for replacing a single broken tile. You can see the application of roof cement in the crevice of the tile.
结论
Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
另外一个人完成了本指南。
Jonathan Fuentes
于01/13/20注册
187 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 45
总计 1,146
