跳转到主内容
Roller Derby Skate Toe Stop Replacement
你所需要的
  1. Roller Derby Skate Toe Stop Replacement, Toe Stop: 步骤 1 中的图像 1,2 Roller Derby Skate Toe Stop Replacement, Toe Stop: 步骤 1 中的图像 2,2
    • Place the roller skate so the heel is touching the table and the toe is pointing up.
  2. Roller Derby Skate Toe Stop Replacement: 步骤 2 中的图像 1,2 Roller Derby Skate Toe Stop Replacement: 步骤 2 中的图像 2,2
    • Loosen the nut with the wrench.
  3. Roller Derby Skate Toe Stop Replacement: 步骤 3 中的图像 1,3 Roller Derby Skate Toe Stop Replacement: 步骤 3 中的图像 2,3 Roller Derby Skate Toe Stop Replacement: 步骤 3 中的图像 3,3
    • Twist the toe stop off with your hand.
  4. Roller Derby Skate Toe Stop Replacement: 步骤 4 中的图像 1,3 Roller Derby Skate Toe Stop Replacement: 步骤 4 中的图像 2,3 Roller Derby Skate Toe Stop Replacement: 步骤 4 中的图像 3,3
    • Twist and remove the washer, split lock washer, and nut with your hand.
  5. Roller Derby Skate Toe Stop Replacement: 步骤 5 中的图像 1,3 Roller Derby Skate Toe Stop Replacement: 步骤 5 中的图像 2,3 Roller Derby Skate Toe Stop Replacement: 步骤 5 中的图像 3,3
    • Place the nut, split lock washer, and washer on your new toe stop.
  6. Roller Derby Skate Toe Stop Replacement: 步骤 6 中的图像 1,1
    • Align the thread of the toe stop screw with the thread on the skate.
    • The threads on the bolt are a soft metal and can bend, chip or break if you force the thread when screwing the toe stop back on.
  7. Roller Derby Skate Toe Stop Replacement: 步骤 7 中的图像 1,1
    • Twist the toe stop back on with your hand.
  8. Roller Derby Skate Toe Stop Replacement: 步骤 8 中的图像 1,3 Roller Derby Skate Toe Stop Replacement: 步骤 8 中的图像 2,3 Roller Derby Skate Toe Stop Replacement: 步骤 8 中的图像 3,3
    • Tighten the nut with the wrench to secure the toe stop in place.
    • Do not over tighten the nut as this can damage the threads on the toe stop or the skate.
    • You will know it's tight enough when you can no longer twist the toe stop off with your hand.
结论
Repeat these steps for each roller skate you wish to replace the toe stop on.
Fabrizio Lopez
于09/29/21注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 1,058
