本指南有最近更改,您可查看未经巡查的最新版本。
简介
To do this replacement you need to make sure you have the correct size allen wrench and the washer fits properly because each roller blade has different specifications. If you do not put the washer on correctly it could cause the wheels to not spin as freely as they should. This fix is neccesary because if the washer is warped the wheels wont spin well or at all causing the front wheel to lock up.
你所需要的
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
另外一个人完成了本指南。
3条评论
ভিঢা বাজার অগ্রণী ব্যাংকের
