跳转到主内容
Roller Blade Washer Replacement
你所需要的
  1. Roller Blade Washer Replacement, Washer: 步骤 1 中的图像 1,1
    • The roller blade needs to be side down on a flat surface
  2. Roller Blade Washer Replacement: 步骤 2 中的图像 1,1
    • Use an Allen Wrench to unscrew the screws on each side of the wheel.
  3. Roller Blade Washer Replacement: 步骤 3 中的图像 1,1
    • Remove the screws and wheel from the blade.
  4. Roller Blade Washer Replacement: 步骤 4 中的图像 1,1
    • Take the old plastic washer off the long screw.
  5. Roller Blade Washer Replacement: 步骤 5 中的图像 1,1
    • Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
  6. Roller Blade Washer Replacement: 步骤 6 中的图像 1,1
    • Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
  7. Roller Blade Washer Replacement: 步骤 7 中的图像 1,1
    • Reinsert the screws through the plastic washers and wheel.
  8. Roller Blade Washer Replacement: 步骤 8 中的图像 1,1
    • Lastly, tighten the screws with the Allen Wrench.
结论
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
另外一个人完成了本指南。
Humza Khan
于02/10/16注册
125 声望
撰写一个指南
团队
3条评论
ভিঢা বাজার অগ্রণী ব্যাংকের
হাসিবুর রহমান - 回复
হাসিবুর রহমান - 回复
হাসিবুর রহমান - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 19
总计 2,448
