跳转到主内容
Roland TR-505 LCD Display Replacement
  1. Roland TR-505 LCD Display Replacement, Removing the dial cap: 步骤 1 中的图像 1,1
    • Simply firmly hold the cap and carefully pull up and the cap should pop up.
  2. Roland TR-505 LCD Display Replacement, Potential Cleaning: 步骤 2 中的图像 1,1
    • Bonus Step!
    • While the cap is off it can be worth cleaning under the cap to prevent dirt from getting inside.
    • This whole guide applies for both dials as they both come off the same way.
  3. Roland TR-505 LCD Display Replacement, Removing the bottom screws: 步骤 3 中的图像 1,1
    • Remove these Philips PH1 screws
    • Not all screws are the same,make sure to keep them organised:-)
  4. Roland TR-505 LCD Display Replacement, Opening the Device: 步骤 4 中的图像 1,2 Roland TR-505 LCD Display Replacement, Opening the Device: 步骤 4 中的图像 2,2
    • Carefully separate the 2 half’s
    • If it’s not coming apart you may need a plastic pry tool to assist you
    • Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
  5. Roland TR-505 LCD Display Replacement, Unplugging the connectors: 步骤 5 中的图像 1,1
    • Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
    • Do not pull on the cable itself as you risk pulling the cables out of the connector
  6. Roland TR-505 LCD Display Replacement, Disassembling the top half: 步骤 6 中的图像 1,1
    • with the connectors disconnected you can lift the top half away.
    • to take the LCD out, take out these PH 1 Philips screws
  7. Roland TR-505 LCD Display Replacement, Removing the LCD: 步骤 7 中的图像 1,1
    • You can now carefully remove the LCD
    • try not to touch the front for the LCD as that will put finder prints onto it, these can be hard to remove and can scratch the LCD(same apples for the plastic lens on the front
结论
另外一个人完成了本指南。
HelloMacOS
于01/24/22注册
27,189 声望
创作了11篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
32 名成员
创作了1,571篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 646
