跳转到主内容
Roku XD 2050X Remote Motherboard Replacement
你所需要的
  1. Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: 步骤 1 中的图像 1,2 Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: 步骤 1 中的图像 2,2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Motherboard Replacement: 步骤 2 中的图像 1,2 Roku XD 2050X Remote Motherboard Replacement: 步骤 2 中的图像 2,2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Motherboard Replacement: 步骤 3 中的图像 1,1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Motherboard Replacement, Remote Motherboard: 步骤 6 中的图像 1,1
    • Now that the remote is disassembled, you simply need to reassemble the remote using the replacement circuit board.
    • Be sure to dispose of the faulty circuit board properly. Recycle if possible!
结论
To reassemble the remote once you've replaced the circuit board, return to the remote control disassembly page and follow the steps in reverse order.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,195
