跳转到主内容
Roku Streaming Stick Motherboard Port replacement
你所需要的
  1. Roku Streaming Stick Motherboard Port replacement, Roku Streaming Stick Motherboard Port: 步骤 1 中的图像 1,1
    • Grab the blue plastic opening tool to open the Roku Streaming Stick 3500R.
  2. Roku Streaming Stick Motherboard Port replacement: 步骤 2 中的图像 1,2 Roku Streaming Stick Motherboard Port replacement: 步骤 2 中的图像 2,2
    • Place the blue plastic opening tool into one of the cracks on the back of the Roku to pop open the Roku Streaming Stick 3500R. Be careful not to break anything while removing the back.
  3. Roku Streaming Stick Motherboard Port replacement: 步骤 3 中的图像 1,1
    • Once you have removed the cover, you can now access the motherboard of the Roku Streaming Stick.
  4. Roku Streaming Stick Motherboard Port replacement: 步骤 4 中的图像 1,2 Roku Streaming Stick Motherboard Port replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the motherboard by grabbing a hold of the micro-usb port, or you can also use tweezers to grab a hold of it and pull it out. But be careful with where you grab the motherboard.
  5. Roku Streaming Stick Motherboard Port replacement: 步骤 5 中的图像 1,3 Roku Streaming Stick Motherboard Port replacement: 步骤 5 中的图像 2,3 Roku Streaming Stick Motherboard Port replacement: 步骤 5 中的图像 3,3
    • Once you identify the HDMI port and the micro-usb port, you can investigate to see which port may be damaged.
  6. Roku Streaming Stick Motherboard Port replacement: 步骤 6 中的图像 1,2 Roku Streaming Stick Motherboard Port replacement: 步骤 6 中的图像 2,2
    • Once you have identified the problem you can then desolder the points at the HDMI as highlighted, or at the micro-usb ports.
    • If the soldering gun, or iron is set too high you then run the risk of destroying the motherboard altogether, or even damaging the wireless antennas.
结论
If the replacement of the motherboard does not work, another part may need to be replaced.
For reassembly, follow instructions in reverse order.
4等其他人完成本指南。
Andy Miller
于04/07/18注册
203 声望
撰写一个指南
团队
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S2G2
4 名成员
创作了3篇指南
一条评论
Any idea where to buy a new hdmi port to solder on?
exxonchavez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 3,851
