跳转到主内容
Roku Streaming Stick Battery Coil Contact Replacement
你所需要的
  1. Roku Streaming Stick Battery Coil Contact Replacement, Battery Coil Contact: 步骤 1 中的图像 1,2 Roku Streaming Stick Battery Coil Contact Replacement, Battery Coil Contact: 步骤 1 中的图像 2,2
    • Flip the remote so that the buttons lay face down and then remove the back cover.
  2. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries by compressing the spring.
    • This will expose the screw shown in red.
  3. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 3 中的图像 1,1
    • Remove the screw using a Phillips #00 screwdriver.
  4. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 4 中的图像 1,2 Roku Streaming Stick Battery Coil Contact Replacement: 步骤 4 中的图像 2,2
    • Remove the face of the remote with the plastic opening tool.
  5. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 5 中的图像 1,2 Roku Streaming Stick Battery Coil Contact Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the motherboard from the remote.
  6. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 6 中的图像 1,1
    • The contacts should be present with one set being in the bottom of the remote casing and the other set being on the underside of the motherboard for the remote.
  7. Roku Streaming Stick Battery Coil Contact Replacement: 步骤 7 中的图像 1,2 Roku Streaming Stick Battery Coil Contact Replacement: 步骤 7 中的图像 2,2
    • This step will require a soldering iron.
    • Now you will have to remove the existing contacts by way of clipping the line of at an appropriate length away from the contacts.
    • Now solder on your new connections on the board.
    • For the connections to the casing, you should be able to remove them with a little force. If you feel like you are using too much force, feel free to use a heat gun to eliminate some adhesive on the casing side of the contact.
    • Finally, adhere the new contacts to the casing with a "super glue" like Krazy glue.
结论
Thomas Kennedy
于04/07/18注册
231 声望
撰写一个指南
团队
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S2G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 1,825
