跳转到主内容
Roku N1000 Motherboard Replacement
你所需要的
  1. Roku N1000 Motherboard Replacement, Remove Bottom Screws: 步骤 1 中的图像 1,2 Roku N1000 Motherboard Replacement, Remove Bottom Screws: 步骤 1 中的图像 2,2
    • Remove the Philips head screws on the bottom side if the Roku box.
  2. Roku N1000 Motherboard Replacement, Bottom Half of Case: 步骤 2 中的图像 1,1
    • Starting from the back of the box, begin to remove the the bottom of the Roku box using the prying tool.
    • Inside the Roku box on the bottom portion of the case, there are two tabs on both the left and right side.
    • Carefully pop the tabs out and lift the side with the prying tool.
  3. Roku N1000 Motherboard Replacement, Removing the Motherboard: 步骤 3 中的图像 1,2 Roku N1000 Motherboard Replacement, Removing the Motherboard: 步骤 3 中的图像 2,2
    • Remove the two Philips screws on the motherboard and the screw on the back panel of the Roku box.
    • Carefully lift the Motherboard out of the Roku box.
结论
Ryan Foley
于10/19/14注册
101 声望
撰写一个指南
团队
Montana Tech, Team 1-5, Shirk Fall 2014 Montana Tech, Team 1-5, Shirk Fall 2014 的会员
MTUM-SHIRK-F14S1G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 779
