跳转到主内容
加入维修社区 - 创建账户
Roku 4 Motherboard Replacement
你所需要的
    1. Roku 4 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
      询问修复机器人
      添加评论
    2. Roku 4 Motherboard Replacement: 步骤 2 中的图像 1,1
      • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
      • Completely remove the rubber sticker to reveal the underlying screws on the device.
      • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
      询问修复机器人
      添加评论
    3. Roku 4 Motherboard Replacement: 步骤 3 中的图像 1,1
      • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
      • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
      询问修复机器人
      添加评论
    4. Roku 4 Motherboard Replacement: 步骤 4 中的图像 1,2 Roku 4 Motherboard Replacement: 步骤 4 中的图像 2,2
      • Turn the device over so you can see the "4" on the top cover.
      询问修复机器人
      添加评论
    5. Roku 4 Motherboard Replacement: 步骤 5 中的图像 1,2 Roku 4 Motherboard Replacement: 步骤 5 中的图像 2,2
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
      • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      询问修复机器人
      添加评论
    6. Roku 4 Motherboard Replacement: 步骤 6 中的图像 1,1
      • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
      • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
      询问修复机器人
      添加评论
    7. Roku 4 Motherboard Replacement: 步骤 7 中的图像 1,3 Roku 4 Motherboard Replacement: 步骤 7 中的图像 2,3 Roku 4 Motherboard Replacement: 步骤 7 中的图像 3,3
      • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
      • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
      询问修复机器人
      添加评论
    8. Roku 4 Motherboard Replacement: 步骤 8 中的图像 1,3 Roku 4 Motherboard Replacement: 步骤 8 中的图像 2,3 Roku 4 Motherboard Replacement: 步骤 8 中的图像 3,3
      • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
      • Repeat this step for the strip that attaches the black and red wires to the motherboard.
      询问修复机器人
      添加评论
    9. Roku 4 Motherboard Replacement: 步骤 9 中的图像 1,3 Roku 4 Motherboard Replacement: 步骤 9 中的图像 2,3 Roku 4 Motherboard Replacement: 步骤 9 中的图像 3,3
      • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
      • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
      • The motherboard should now be completely disconnected from the top cover of the device.
      添加评论
结论
Follow these steps in the reverse order to reassemble your device.
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 的会员
BU-WILLIAMS-S17S5G4
3 名成员
创作了19篇指南
4指南评论
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - 回复 分享
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - 回复 分享
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man - 回复 分享
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 53
总计 6,426
