跳转到主内容
Roku 3 Remote Control Motherboard Replacement
你所需要的
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: 步骤 1 中的图像 1,1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: 步骤 2 中的图像 1,2 Roku 3 Remote Control Motherboard Replacement: 步骤 2 中的图像 2,2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 4 中的图像 1,2 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 4 中的图像 2,2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: 步骤 5 中的图像 1,2 Roku 3 Remote Control Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: 步骤 6 中的图像 1,2 Roku 3 Remote Control Motherboard Replacement: 步骤 6 中的图像 2,2
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: 步骤 7 中的图像 1,1
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G2
3 名成员
创作了6篇指南
4条评论
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - 回复
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - 回复
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 5,093
