跳转到主内容
Roku 2 Remote Battery Replacement
你所需要的
  1. Roku 2 Remote Battery Replacement, Remote Battery: 步骤 1 中的图像 1,1
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Battery Replacement: 步骤 2 中的图像 1,1
    • Remove batteries
  3. Roku 2 Remote Battery Replacement: 步骤 3 中的图像 1,1
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
结论
3等其他人完成本指南。
Alex Saltos
于08/27/15注册
526 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G5
3 名成员
创作了7篇指南
一条评论
Now Roku remotes comes with various features. To access these features you have to pair the Roku remote. If you want any help regarding Roku remote go to website: Roku Com Link
Katherine Melinda - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 6,498
