跳转到主内容
Roku 2 Case Replacement
你所需要的
  1. Roku 2 Case Replacement, Case: 步骤 1 中的图像 1,1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • Note: It may take several heats, left for a minute at a time, to loosen the glue.
  2. Roku 2 Case Replacement: 步骤 2 中的图像 1,1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Case Replacement: 步骤 3 中的图像 1,1
    • Use the 000 phillips to remove the screws found under all four of the rubber pads.
  4. Roku 2 Case Replacement: 步骤 4 中的图像 1,1
    • Gently remove the under side of the device.
  5. Roku 2 Case Replacement: 步骤 5 中的图像 1,1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Case Replacement: 步骤 6 中的图像 1,1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Case Replacement: 步骤 7 中的图像 1,1
    • Remove the board from the plastic enclosure and put the board into the replacement enclosure.
结论
另外一个人完成了本指南。
Eric Rawls
于08/24/15注册
360 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G5
3 名成员
创作了7篇指南
一条评论
cause mine get’s hot and it’s slow as !&&*
brian price - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 747
