简介
The sender and receiver each contain an audio module chip that connect wirelessly for proper functioning of the Rocketfish RF-WHTIB-A system. An unresponsive sender during connection mode on the does not necessarily mean the device is entirely broken. It could indicate a problem with the wireless audio module chip. This guide will direct users step by step to replacing a faulty wireless audio module chip.
你所需要的
Remove the four rubber tabs from the bottom of the sender.
Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
To install the new wireless module chip, follow these instructions in reverse order.
Once the sender has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new wireless module chip has been properly assembled.
2条评论
“No Parts Required” is a joke . Where are the replacement boards available from?
