跳转到主内容
Road Bike Presta Valve Inner Tube Replacement
你所需要的
  1. Road Bike Presta Valve Inner Tube Replacement, Presta Valve Inner Tube: 步骤 1 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement, Presta Valve Inner Tube: 步骤 1 中的图像 2,2
    • Flip the bike upside down.
  2. Road Bike Presta Valve Inner Tube Replacement: 步骤 2 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 2 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 2 中的图像 3,3
    • Find the Presta valve of the tire, then remove the cap by turning counter-clockwise.
  3. Road Bike Presta Valve Inner Tube Replacement: 步骤 3 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 3 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 3 中的图像 3,3
    • Twist the tip of the Presta valve counter-clockwise.
  4. Road Bike Presta Valve Inner Tube Replacement: 步骤 4 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 4 中的图像 2,2
    • Press firmly on the valve to release the air in the tube.
    • Hold firmly until there is no more air left.
  5. Road Bike Presta Valve Inner Tube Replacement: 步骤 5 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 5 中的图像 2,2
    • Lift the lever on the brake assembly of the wheel to release the brakes.
  6. Road Bike Presta Valve Inner Tube Replacement: 步骤 6 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 6 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 6 中的图像 3,3
    • Unscrew the cap of the front wheel spoke by turning it counter-clockwise.
  7. Road Bike Presta Valve Inner Tube Replacement: 步骤 7 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 7 中的图像 2,2
    • Firmly grab the lever on the other side of the spoke and lift it up.
  8. Road Bike Presta Valve Inner Tube Replacement: 步骤 8 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 8 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 8 中的图像 3,3
    • Grab the top of the wheel, and gently lift it off the frame of the bike.
  9. Road Bike Presta Valve Inner Tube Replacement: 步骤 9 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 9 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 9 中的图像 3,3
    • Find the Presta valve, and unscrew the nut at the bottom of the Presta valve.
  10. Road Bike Presta Valve Inner Tube Replacement: 步骤 10 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 10 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 10 中的图像 3,3
    • Insert the two tire levers on the opposite side of the Presta Valve, placing each one about 10 inches apart.
    • The side the levers are on doesn't matter, but ensure both levers are on the same side of the wheel.
  11. Road Bike Presta Valve Inner Tube Replacement: 步骤 11 中的图像 1,1
    • Push both tire levers down until the tire lifts off the rim.
  12. Road Bike Presta Valve Inner Tube Replacement: 步骤 12 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 12 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 12 中的图像 3,3
    • Firmly push the side of the tire that is off the rim.
    • Repeat the action of pushing around the entire wheel until one side of the wheel is off the rim.
  13. Road Bike Presta Valve Inner Tube Replacement: 步骤 13 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 13 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 13 中的图像 3,3
    • Grab the inner tube from the inside of the tire, and pull the rest of the tube out.
    • Remove the inner tube from the wheel by pulling the part of the tube that is attached to the Presta Valve until the valve slides out from the wheel.
  14. Road Bike Presta Valve Inner Tube Replacement: 步骤 14 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 14 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 14 中的图像 3,3
    • With the new tube, insert the Presta valve into the hole of the rim.
    • If there is a nut on the Presta Valve, make sure it is off before you insert the tube into the rim.
  15. Road Bike Presta Valve Inner Tube Replacement: 步骤 15 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 15 中的图像 2,2
    • Starting from where the valve is, push the side of the tire that was off the rim back onto the rim, making sure the tube is inside the tire.
    • Repeat this going down the right side of the tire, stopping at halfway point of the rim.
  16. Road Bike Presta Valve Inner Tube Replacement: 步骤 16 中的图像 1,1
    • Push in the tire from the left side of the rim, and repeat this going down the rim until it gets too difficult to push anymore.
  17. Road Bike Presta Valve Inner Tube Replacement: 步骤 17 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 17 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 17 中的图像 3,3
    • Insert the tire lever before the last bit of the tire that is not in the rim.
    • Grab the rim with one hand, and use your other hand to grab the tire lever and push down until the tire is back on the rim.
  18. Road Bike Presta Valve Inner Tube Replacement: 步骤 18 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 18 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 18 中的图像 3,3
    • Twist the nut for the Presta valve clockwise until it secures the Presta valve.
  19. Road Bike Presta Valve Inner Tube Replacement: 步骤 19 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 19 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 19 中的图像 3,3
    • Grab the wheel and put it back on the fork of the bike.
  20. Road Bike Presta Valve Inner Tube Replacement: 步骤 20 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 20 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 20 中的图像 3,3
    • Screw the Presta valve cap back on the Presta valve.
  21. Road Bike Presta Valve Inner Tube Replacement: 步骤 21 中的图像 1,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 21 中的图像 2,3 Road Bike Presta Valve Inner Tube Replacement: 步骤 21 中的图像 3,3
    • Loosely tighten the cap of the spoke by turning the cap clockwise.
    • Stop when you start to feel the cap is pressing against the fork.
  22. Road Bike Presta Valve Inner Tube Replacement: 步骤 22 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 22 中的图像 2,2
    • Push the lever on the spoke down.
  23. Road Bike Presta Valve Inner Tube Replacement: 步骤 23 中的图像 1,2 Road Bike Presta Valve Inner Tube Replacement: 步骤 23 中的图像 2,2
    • Push down the brake lever.
结论
kb03
于04/15/24注册
337 声望
撰写一个指南
团队
UC Davis, Team 1-6, Morris Spring 2024 UC Davis, Team 1-6, Morris Spring 2024 的会员
UCD-MORRIS-S24S1G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 53
