跳转到主内容
Rival Mini Chopper MC-67BL Safety Latch Replacement
你所需要的
  1. Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: 步骤 1 中的图像 1,2 Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: 步骤 1 中的图像 2,2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 3 中的图像 1,1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 4 中的图像 1,1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 5 中的图像 1,2 Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 6 中的图像 1,1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 7 中的图像 1,1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 8 中的图像 1,3 Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 8 中的图像 2,3 Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 8 中的图像 3,3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Safety Latch Replacement, Power Button: 步骤 9 中的图像 1,1
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 10 中的图像 1,1
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 11 中的图像 1,1
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 12 中的图像 1,2 Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body and set it aside.
  13. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 13 中的图像 1,2 Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 13 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
    • Next, turn the device upright and lift the upper casing from around the button gently.
  14. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 14 中的图像 1,1
    • Remove the button by simply pulling it up.
    • Don't lose the spring under the button! Without it, the blender will not function.
  15. Rival Mini Chopper MC-67BL Safety Latch Replacement, Safety Latch: 步骤 15 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove one 9.53-mm screw.
  16. Rival Mini Chopper MC-67BL Safety Latch Replacement: 步骤 16 中的图像 1,1
    • Remove the white latch by unhooking it from the spring wire and gently lifting straight up.
结论
Roxanne
于10/17/13注册
522 声望
创作了4篇指南
团队
Cal Poly, Team 4-29, Amido Fall 2013 Cal Poly, Team 4-29, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G29
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,469
