简介
This guide will show you how to disassemble a Rival Crock Pot model 3120. None of the components in the device are extremely fragile, but you should still be careful while performing the steps in this guide. Make sure before starting that your device is not plugged in, and that if it was turned on ensure it has had time to cool down fully. The only tools required are a 10mm and 16mm wrench, but an adjustable wrench or pliers could be used instead. This guide may be helpful for accessing the rotary switch of it is faulty or for replacing the heating element(s) if it burns out. The crock pot has a very simple design and very few components, so repairs should be straightforward.
你所需要的
精选文档
Remove the lid from the crockpot and turn the device over, so that the bottom faces up.
