当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a toothbrush, clean the entire cleat, especially where the shoe is ripped.
The toothbrush will help get any excess dirt or turf out from under the ripped area.
Squeeze out a good amount of the Shoe Goo onto the piece of printer paper.
Shoe Goo will help adhere the sole of the cleat to the leather.
Be sure to have a clean air source in the room, as this glue has strong fumes.
Using the paint brush, paint the glue in the opening of the ripped cleat and between the leather and the sole of the cleat.
The glue is very sticky and dries fast. Make sure to paint it inside the rip as soon as you squeeze the glue out onto the paper.
Let dry for 3 minutes and repeat the step again.
Use a hair dryer to slowly warm the newspaper surrounding the tear. Do this for 10 minutes, then let the shoe rest.
Make sure to hold the hair dryer 4-6 inches away so the tape and newspaper don't over heat as glue might bubble.
After 24 hours, remove the tape and newspaper.
Then once the tape and newspaper are removed, peel off any excess glue that is stuck around the area of the rip.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
