简介
This guide will explain step-by-step how to replace the speaker in a Ring Video Doorbell Pro.
你所需要的
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
Remove the speaker from the device.
To reassemble your device, insert the new speaker and follow these instructions in reverse order.
6等其他人完成本指南。
7条评论
Hi Jake. This looks brilliant - I would love to contact you directly as I have a further question about this. My member name is robinfeild, and my email is email is robinfeild@gmail.com.
Hope to hear from you!
Thanks
Robin
Anyone happen to know where you can purchase the replacement speaker from?
John Clark - 回复
Where did you get a replacement speaker from?
I dismantled the speaker in mine having verified it was faulty by testing it with one from a standard Ring Doorbell, (It has the same connector but the housing is a different shape. Having cracked open the plastic housing of the speaker it has one of these inside (1w 8 Ohm Rectangular speaker 15*11*3.5mm) such as https://www.ebay.co.uk/itm/224485373996 a couple of drops of superglue and two dabs of solder, works like new.
Where did you get a replacement speaker from ?
Hi jake where did u get the speaker from? Can you send link please, need speaker for ring doorbell 3 plus!
