跳转到主内容
加入维修社区 - 创建账户
Ring Video Doorbell Pro Speaker Replacement
你所需要的
  1. Ring Video Doorbell Pro Speaker Replacement, Housing: 步骤 1 中的图像 1,1
    • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
  2. Ring Video Doorbell Pro Speaker Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell Pro Speaker Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell Pro Speaker Replacement: 步骤 2 中的图像 3,3
    • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
  3. Ring Video Doorbell Pro Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
  4. Ring Video Doorbell Pro Speaker Replacement: 步骤 4 中的图像 1,2 Ring Video Doorbell Pro Speaker Replacement: 步骤 4 中的图像 2,2
    • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
  5. Ring Video Doorbell Pro Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the front of the device from the back plate.
  6. Ring Video Doorbell Pro Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • With the Video Doorbell Pro opened up the speaker is exposed.
  7. Ring Video Doorbell Pro Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove this 5.25 mm screw.
  8. Ring Video Doorbell Pro Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove this wire connection by gently prying it off with a plastic pry tool.
  9. Ring Video Doorbell Pro Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the speaker from the device.
结论
To reassemble your device, insert the new speaker and follow these instructions in reverse order.
6等其他人完成本指南。
Jake Dixon
于11/09/17注册
901 声望
创作了4篇指南
团队
IUPUI, Team S7-G4, Baechle Fall 2017 IUPUI, Team S7-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G4
3 名成员
创作了5篇指南
8指南评论
Hi Jake. This looks brilliant - I would love to contact you directly as I have a further question about this. My member name is robinfeild, and my email is email is robinfeild@gmail.com.
Hope to hear from you!
Thanks
Robin
Robin Feild - 回复 分享
Anyone happen to know where you can purchase the replacement speaker from?
John Clark - 回复 分享
Where did you get a replacement speaker from?
Volodymyr Kazantsev - 回复 分享
Sammy - 回复 分享
I dismantled the speaker in mine having verified it was faulty by testing it with one from a standard Ring Doorbell, (It has the same connector but the housing is a different shape. Having cracked open the plastic housing of the speaker it has one of these inside (1w 8 Ohm Rectangular speaker 15*11*3.5mm) such as https://www.ebay.co.uk/itm/224485373996 a couple of drops of superglue and two dabs of solder, works like new.
cagedbat - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 36
总计 16,064
