跳转到主内容
Ring Video Doorbell Pro Motherboard Replacement
你所需要的
  1. Ring Video Doorbell Pro Motherboard Replacement, Housing: 步骤 1 中的图像 1,1
    • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
  2. Ring Video Doorbell Pro Motherboard Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell Pro Motherboard Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell Pro Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
  3. Ring Video Doorbell Pro Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
  4. Ring Video Doorbell Pro Motherboard Replacement: 步骤 4 中的图像 1,2 Ring Video Doorbell Pro Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
  5. Ring Video Doorbell Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the front of the device from the back plate.
  6. Ring Video Doorbell Pro Motherboard Replacement, Speaker: 步骤 6 中的图像 1,1
    • With the Video Doorbell Pro opened up the speaker is exposed.
  7. Ring Video Doorbell Pro Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove this 5.25 mm screw.
  8. Ring Video Doorbell Pro Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove this wire connection by gently prying it off with a plastic pry tool.
  9. Ring Video Doorbell Pro Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the speaker from the device.
  10. Ring Video Doorbell Pro Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • The next step is to remove the last four connections holding the motherboard in place.
  11. Ring Video Doorbell Pro Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using the plastic pry tool, carefully remove this wire connection.
  12. Ring Video Doorbell Pro Motherboard Replacement: 步骤 12 中的图像 1,1
    • Using the plastic pry tool, gently ease this ribbon cable from its port.
  13. Ring Video Doorbell Pro Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the last two wire connections shown here using the same methods utilized in the previous steps.
  14. Ring Video Doorbell Pro Motherboard Replacement: 步骤 14 中的图像 1,2 Ring Video Doorbell Pro Motherboard Replacement: 步骤 14 中的图像 2,2
    • Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
  15. Ring Video Doorbell Pro Motherboard Replacement: 步骤 15 中的图像 1,1
    • Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
结论
To reassemble your device, insert the new motherboard and follow these instructions in reverse order.
8等其他人完成本指南。
Jake Dixon
于11/09/17注册
850 声望
创作了4篇指南
团队
IUPUI, Team S7-G4, Baechle Fall 2017 IUPUI, Team S7-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G4
3 名成员
创作了5篇指南
4条评论
Is this the latest model
Phillip - 回复
A pig to get apart. Prying the case open needed a glaziers flexy putty knife or spark plug feeler gauge as a plastic pry tool is not man enough . Connectors fall apart as you try to disconnect. Battery, aerial and capacitor are all glued or taped together.
You don’t need to disconnect the ribbon cable in Step 10 unless you intend to remove the camera module, which is screwed to the motherboard so comes away with it
Zam Zoo - 回复
thank you very useful - question is i cannot fine a spare main board im after a ring pro mainboard - i open mine and looks like some of the parts are blowen its all green :) do you offer a repair service of main board ?
Sid Hepworth-Lloyd - 回复
Where can I buy a new motherboard please?
Vicky_z - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 44
总计 9,570
