跳转到主内容
Ring Video Doorbell Housing Replacement
你所需要的
  1. Ring Video Doorbell Housing Replacement, Housing: 步骤 1 中的图像 1,3 Ring Video Doorbell Housing Replacement, Housing: 步骤 1 中的图像 2,3 Ring Video Doorbell Housing Replacement, Housing: 步骤 1 中的图像 3,3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Housing Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell Housing Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell Housing Replacement: 步骤 2 中的图像 3,3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell Housing Replacement: 步骤 3 中的图像 1,3 Ring Video Doorbell Housing Replacement: 步骤 3 中的图像 2,3 Ring Video Doorbell Housing Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell Housing Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic film using the Plastic Tool Opener.
结论
3等其他人完成本指南。
Abdulrahman
于02/20/18注册
685 声望
创作了3篇指南
团队
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G5
3 名成员
创作了10篇指南
一条评论
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Charlie Adamson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 3,083
