跳转到主内容
Ring Video Doorbell Battery Replacement
你所需要的
  1. Ring Video Doorbell Battery Replacement, Battery: 步骤 1 中的图像 1,3 Ring Video Doorbell Battery Replacement, Battery: 步骤 1 中的图像 2,3 Ring Video Doorbell Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell Battery Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell Battery Replacement: 步骤 2 中的图像 3,3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
结论
3等其他人完成本指南。
Abdulrahman
于02/20/18注册
709 声望
创作了3篇指南
团队
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G5
3 名成员
创作了10篇指南
7指南评论
Where do I get a replacement battery?
William Price - 回复
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - 回复
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - 回复
can it be sent to the manufacturers for a replacement
d.rayyan - 回复
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 109
过去 30 天: 469
总计 16,115
