跳转到主内容
加入维修社区 - 创建账户
Ring Video Doorbell Speakers Replacement
你所需要的
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: 步骤 1 中的图像 1,3 Ring Video Doorbell  Speakers Replacement, Motherboard: 步骤 1 中的图像 2,3 Ring Video Doorbell  Speakers Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Speakers Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell  Speakers Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell  Speakers Replacement: 步骤 2 中的图像 3,3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Speakers Replacement: 步骤 3 中的图像 1,3 Ring Video Doorbell  Speakers Replacement: 步骤 3 中的图像 2,3 Ring Video Doorbell  Speakers Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Speakers Replacement: 步骤 4 中的图像 1,2 Ring Video Doorbell  Speakers Replacement: 步骤 4 中的图像 2,2
    • Detach the upper part of the motherboard from the bottom, using your hands.
  5. Ring Video Doorbell  Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Speakers are two small rectangles located above the button of the doorbell.
  6. Ring Video Doorbell  Speakers Replacement: 步骤 6 中的图像 1,1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G5
3 名成员
创作了10篇指南
1指南评论
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 79
总计 5,597
