简介
In this guide, you will be shown how to take apart and replace the camera of the Ring Video Doorbell step-by-step. You will need a Phillips screwdriver size PH00 and a Plastic Tool Opener.
你所需要的
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminum plate using the Plastic Opening Tool(s).
Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
Replace camera, and follow the steps in reverse order to reassemble
Where do you find the replacement camera dropped mine and cameras lens busted?
3等其他人完成本指南。
8条评论
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
What camera should I use to replace? (Scratched Lens.) I have the right 1st generation with a 740p camera
meanltltoo - 回复
Has anyone found a replacement camera online?
I also need to know where to buy the replacement lens?? I’m not seeing that question answered by anyone….
Dawn Smith - 回复
