跳转到主内容
Ring Video Doorbell Camera Replacement
你所需要的
  1. Ring Video Doorbell  Camera Replacement, Camera: 步骤 1 中的图像 1,3 Ring Video Doorbell  Camera Replacement, Camera: 步骤 1 中的图像 2,3 Ring Video Doorbell  Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminum plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Camera Replacement: 步骤 2 中的图像 1,3 Ring Video Doorbell  Camera Replacement: 步骤 2 中的图像 2,3 Ring Video Doorbell  Camera Replacement: 步骤 2 中的图像 3,3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Camera Replacement: 步骤 3 中的图像 1,3 Ring Video Doorbell  Camera Replacement: 步骤 3 中的图像 2,3 Ring Video Doorbell  Camera Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Camera Replacement: 步骤 4 中的图像 1,2 Ring Video Doorbell  Camera Replacement: 步骤 4 中的图像 2,2
    • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
    • Replace camera, and follow the steps in reverse order to reassemble
    Where do you find the replacement camera dropped mine and cameras lens busted?
    Michelle McCord - 回复
    Ok now now that you told me how to replace the camera. Where can I buy a camera to replace my scratched and broken lens?
    Help!??
    Evrt M - 回复
    Same here, where do you get the replacement from?
    Steve.D70 - 回复
  5. Ring Video Doorbell  Camera Replacement: 步骤 5 中的图像 1,2 Ring Video Doorbell  Camera Replacement: 步骤 5 中的图像 2,2
    • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
    • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
结论
3等其他人完成本指南。
Isaiah Wilson
于02/20/18注册
231 声望
撰写一个指南
团队
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G5
3 名成员
创作了10篇指南
8条评论
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - 回复
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - 回复
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend -
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - 回复
Has anyone found a replacement camera online?
christina.stewart - 回复
So what's up with trying to find a replacement camera cuz my lens is broken?
Evrt M - 回复
I also need to know where to buy the replacement lens?? I’m not seeing that question answered by anyone….
Dawn Smith - 回复
Same here, pointless showing how to replace it if we don’t know where to get a replacement other than a used item.
Steve.D70 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 154
总计 15,625
