跳转到主内容
加入维修社区 - 创建账户
Ring Video Battery and Wi-Fi Antenna Replacement.
  1. Ring Video Battery and Wi-Fi Antenna Replacement., Battery and Wi-Fi antenna: 步骤 1 中的图像 1,1
    • Battery made of 2 units and a controller card with a 5-wire output. This battery can possibly be replaced by another one of the same final voltage, either by a parallel arrangement or by a direct connection of a unit.
    • The final amperage doesn´t need to be the same as the original battery.
    • The shape of the new battery doesn´t need to be the same either, since it can be placed externally just by inserting the cables.
    询问修复机器人
    添加评论
  2. Ring Video Battery and Wi-Fi Antenna Replacement.: 步骤 2 中的图像 1,1
    • Both options, using the controller card to facilitate the connection to the main motherboard, so it can recognize the power source.
    询问修复机器人
    添加评论
  3. Ring Video Battery and Wi-Fi Antenna Replacement.: 步骤 3 中的图像 1,1
    • The main motherboard with antenna card, and the chance of upgrading it with a generic antenna, improving reception and transmission.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order
取消:我没有完成这个指南。
由衷感谢以下译者:
es en
100%
Penny正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
AZUL BOCANDREA
于01/14/21注册
97 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 45
总计 1,557
