跳转到主内容
Ring Stick Up Cam Microphone Replacement
你所需要的
  1. Ring Stick Up Cam Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Microphone Replacement: 步骤 2 中的图像 1,1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Microphone Replacement: 步骤 3 中的图像 1,1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Microphone Replacement: 步骤 4 中的图像 1,1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Microphone Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Microphone Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Microphone Replacement, Camera: 步骤 7 中的图像 1,1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Microphone Replacement: 步骤 8 中的图像 1,1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Microphone Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Microphone Replacement: 步骤 10 中的图像 1,1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Microphone Replacement: 步骤 11 中的图像 1,1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Microphone Replacement: 步骤 12 中的图像 1,1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Microphone Replacement: 步骤 13 中的图像 1,1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Microphone Replacement, Microphone: 步骤 14 中的图像 1,1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Microphone Replacement: 步骤 15 中的图像 1,1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Microphone Replacement: 步骤 16 中的图像 1,1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
结论
Chunyue Liu
于02/06/19注册
273 声望
创作了2篇指南
团队
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 的会员
UCD-LORE-W19S18G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 2,654
