简介
In this guide, we will show you how to replace the camera in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
你所需要的
Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Where do we buy a new battery from?
Battery specs would be great in this tear down so one can know what battery to get and have everything they need for the repair.
I have these available if you would like one. The specs are 3.75 volt, 5000 mAh nominal. The ones I sell are OEM, used pulls from overstock or upgraded units.
Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
另外一个人完成了本指南。
2条评论
Where can I purchase a new lens?
Any ideas where to get a new lens?
