跳转到主内容
Ring Stick Up Cam Camera Replacement
你所需要的
  1. Ring Stick Up Cam Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Camera Replacement: 步骤 2 中的图像 1,1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Camera Replacement: 步骤 4 中的图像 1,1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Camera Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Camera Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    Where do we buy a new battery from?
    lessonsinflight - 回复
    Battery specs would be great in this tear down so one can know what battery to get and have everything they need for the repair.
    Edward Clark - 回复
    I have these available if you would like one. The specs are 3.75 volt, 5000 mAh nominal. The ones I sell are OEM, used pulls from overstock or upgraded units.
    Solarescycle -
  7. Ring Stick Up Cam Camera Replacement, Camera: 步骤 7 中的图像 1,1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Camera Replacement: 步骤 8 中的图像 1,1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Camera Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Camera Replacement: 步骤 10 中的图像 1,1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Camera Replacement: 步骤 11 中的图像 1,1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Camera Replacement: 步骤 12 中的图像 1,1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Camera Replacement: 步骤 13 中的图像 1,1
    • Lift the camera board out of the housing using your hand.
结论
另外一个人完成了本指南。
Ao Li
于02/06/19注册
245 声望
撰写一个指南
团队
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 的会员
UCD-LORE-W19S18G3
3 名成员
创作了8篇指南
2条评论
Where can I purchase a new lens?
Javier Casas - 回复
Any ideas where to get a new lens?
Mete Doguoglu - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 56
总计 4,481
