跳转到主内容
Ring Stick Up Cam Battery Replacement
你所需要的
  1. Ring Stick Up Cam Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Battery Replacement: 步骤 2 中的图像 1,1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Battery Replacement: 步骤 4 中的图像 1,1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Battery Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
结论
9等其他人完成本指南。
Nicholos Frey
于02/05/19注册
424 声望
撰写一个指南
团队
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 的会员
UCD-LORE-W19S18G3
3 名成员
创作了8篇指南
11条评论
Where can I get a replacement battery?
jbains - 回复
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S -
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - 回复
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - 回复
Would love to replace the battery, if I could find it online…
Matthew Grow - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 80
总计 11,606
