跳转到主内容
Ring Spotlight Cam Battery The Mounting Bracket Replacement
你所需要的
  1. Ring Spotlight Cam Battery The Mounting Bracket  Replacement, The Mounting Bracket: 步骤 1 中的图像 1,1
    • Place Mounting Bracket with lower elevation facing towards you.
  2. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the single bracket screw.
  3. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 步骤 3 中的图像 1,1
    • Hold two corners from the middle of bracket and stretch outward.
  4. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 步骤 4 中的图像 1,1
    • Slide bracket upwards.
结论
一条评论
I have lost the single bracket screw. Where can I get a replacement?
Rick Burgess - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 2,679
