跳转到主内容
Ring Spotlight Cam Battery Motion Detector Replacement
你所需要的
  1. Ring Spotlight Cam Battery Motion Detector Replacement, Motion Detector: 步骤 1 中的图像 1,1
    • Turn Ring Spotlight Cam to the posterior side and flip upside down
  2. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 2 中的图像 1,1
    • Press down on top button and open upward
  3. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 3 中的图像 1,1
    • Make sure to remove the batteries in the Spotlight cam before proceeding with this step!
    • Open the Spotlight Cam upward and remove the two screws with a Phillips #1 screwdriver.
  4. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws down the middle and lift the middle component off
  5. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 5 中的图像 1,1
    • Remove the remaining 10 screws that are around the border under the tape.
  6. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 6 中的图像 1,1
    • Gently close the top of the lid
  7. Ring Spotlight Cam Battery Motion Detector Replacement: 步骤 7 中的图像 1,1
    • Remove the top lid and replace the LED light
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 18
过去 30 天: 64
总计 1,115
