简介
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
你所需要的
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Use the soldering iron to desolder and remove the red, blue, and three black wires.
即将完成!
To reassemble your device, follow steps one through seven in reverse order.
结论
