跳转到主内容
Ridgid R82005 LED Light Replacement
你所需要的
  1. Ridgid R82005 LED Light Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 LED Light Replacement: 步骤 2 中的图像 1,1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 LED Light Replacement: 步骤 3 中的图像 1,2 Ridgid R82005 LED Light Replacement: 步骤 3 中的图像 2,2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 LED Light Replacement: 步骤 4 中的图像 1,2 Ridgid R82005 LED Light Replacement: 步骤 4 中的图像 2,2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005 LED Light Replacement, LED Light: 步骤 5 中的图像 1,2 Ridgid R82005 LED Light Replacement, LED Light: 步骤 5 中的图像 2,2
    • Unplug the LED connector gently.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 279
