跳转到主内容
Ridgid R82005 Housing Assembly Replacement
你所需要的
  1. Ridgid R82005 Housing Assembly  Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 Housing Assembly  Replacement: 步骤 2 中的图像 1,1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Housing Assembly  Replacement: 步骤 3 中的图像 1,2 Ridgid R82005 Housing Assembly  Replacement: 步骤 3 中的图像 2,2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 Housing Assembly  Replacement: 步骤 4 中的图像 1,2 Ridgid R82005 Housing Assembly  Replacement: 步骤 4 中的图像 2,2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
结论
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
2等其他人完成本指南。
Alex Cominos
于02/14/19注册
376 声望
创作了2篇指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 239
