跳转到主内容
Ridgid R82005 2 Speed Gear Train Replacement
你所需要的
  1. Ridgid R82005  2 Speed Gear Train  Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  2 Speed Gear Train  Replacement: 步骤 2 中的图像 1,1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  2 Speed Gear Train  Replacement: 步骤 3 中的图像 1,2 Ridgid R82005  2 Speed Gear Train  Replacement: 步骤 3 中的图像 2,2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  2 Speed Gear Train  Replacement: 步骤 4 中的图像 1,2 Ridgid R82005  2 Speed Gear Train  Replacement: 步骤 4 中的图像 2,2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: 步骤 5 中的图像 1,2 Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: 步骤 5 中的图像 2,2
    • Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
    • The 2 speed gear selector may fall out on its own.
    • When reassembling, make sure all drill components fit properly in the grooves of the Housing Assembly.
结论
4等其他人完成本指南。
团队
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 530
