简介
In order to replace most other parts in the sander, you must remove the top cover. All you will need is a T10 screwdriver. Make sure that the device is unplugged before following this guide.
你所需要的
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
即将完成!
结论
