跳转到主内容
Ridgid R2601 Bearing Replacement
你所需要的
  1. Ridgid R2601 Bearing Replacement, Bearing: 步骤 1 中的图像 1,1
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
  2. Ridgid R2601 Bearing Replacement: 步骤 2 中的图像 1,1
    • Remove the base.
  3. Ridgid R2601 Bearing Replacement: 步骤 3 中的图像 1,1
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
  4. Ridgid R2601 Bearing Replacement: 步骤 4 中的图像 1,1
    • Remove the bearing.
结论
3条评论
What is the bearing size?
Dagan Larson - 回复
The actual bearing appears to be an R002RS.
ID 15mm
OD 32mm
Width: 9mm
I used a large socket to push the bearing out of the squarish bracket. The bearing needs to be pushed out from top to bottom (as it would be oriented when the sander is sitting upright on a surface).
I placed the socket inside the opening in the top, and put screws into the bottom (I happened to have some longer screws with the same thread pitch) to provide clearance for the bearing to come out. Then I pressed it with a vise. Tapping the socket with a hammer would also work.
Joe Porkka - 回复
Shouldn't the title be "How to remove a bearing housing"? You don't give any instructions on how to actually remove the bearing from the housing, nor how to insert a new bearing into the housing and reassembly.
I'm sorry, but it feels like you got part way into the instructions, got bored and said, "eh, it's good enough."
Joseph Brzezicki - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,936
