简介
The Drive Gear Cover for the Ridgid JobMax R8620 Series E is a crucial part of the device because it allows you to have control. If it is not working properly, please view this guide to see how to replace it.
你所需要的
Pull the battery out of the case by hand before opening the device.
Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
Lift off the outer casing.
即将完成!
结论
