跳转到主内容
Ridgid JobMax R2851 Series B Motor Replacement
你所需要的
  1. Ridgid JobMax R2851 Series B Motor Replacement, Motor: 步骤 1 中的图像 1,2 Ridgid JobMax R2851 Series B Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 2 中的图像 1,1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 3 中的图像 1,1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 4 中的图像 1,2 Ridgid JobMax R2851 Series B Motor Replacement: 步骤 4 中的图像 2,2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 5 中的图像 1,3 Ridgid JobMax R2851 Series B Motor Replacement: 步骤 5 中的图像 2,3 Ridgid JobMax R2851 Series B Motor Replacement: 步骤 5 中的图像 3,3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 6 中的图像 1,2 Ridgid JobMax R2851 Series B Motor Replacement: 步骤 6 中的图像 2,2
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Motor Replacement: 步骤 7 中的图像 1,2 Ridgid JobMax R2851 Series B Motor Replacement: 步骤 7 中的图像 2,2
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 685
