跳转到主内容
Ridgid GEN5X R8653 Base Assembly Replacement
你所需要的
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 步骤 1 中的图像 1,3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 步骤 1 中的图像 2,3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 步骤 1 中的图像 3,3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: 步骤 2 中的图像 1,3 Ridgid GEN5X R8653 Base Assembly Replacement: 步骤 2 中的图像 2,3 Ridgid GEN5X R8653 Base Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 9
总计 220
